I had a call on what I thought was a backed-up Washer drain.
We thoroughly augured/cleaned the 2-inch ABS line.
The drain takes all the WATER from the washing machine with NO PROBLEMS.
At the end of the spin cycle, the drain hose from the washing machine produces a LARGE AMOUNT OF FOAM AND SUDS. It is at this time when the 2-inch riser overflows with SUDS/foam. (((NO WATER))))... The drain has discharged all of the water with NO PROBLEMS...
The homeowner says he has used the same detergent for the past 4.5 years. The same detergent, the same amount of detergent, same machine...
Now we have a soap suds party every time the machine hits the end of the spin cycle...
THE LINE IS CLEAR, AND THE TRAP IS CLEAR. IT TAKES OUT ALL OF THE WATER WITH NO PROBLEMS AND NO BACKUP... ONLY SUDS/FOAM.HELP PLEASE
