Just got required by a bellevue, wa inspector to add a trap seal primer to a condensate waste receptor...has anyone else run into this? I thought that the condensate maintains the trap seal just fine... any thoughts?
There is no way out your are in Bellevue, 100% by the book no questions. Yes you are required to have a trap primer 2006 UPC page 132 1007.0 Trap Seal Protection. Bellevue is a bit insane with the book. Got called for air gap discharge to a Dishwasher tee was told it had to go to the Disposal barb which on this sink was above the discharge of the air gap. He stood there while I made the correction. Changed it back when I ran the dishwasher and the air gap squirted.
The left bowl is only 4" deep with a ISE disposer puts the the hose barb of the disposer at 8"+/- below the sink. The discharge leg of the air gap is at 8"+/-and pointing at an angle down. There was no way to get it level more or less right.A little off topic but PlumberDave, how in the world can your airgap be below the disposer connection? Your airgap should be above the flood level rim of the SINK![]()
The trap seal ain't gonna evaporate over the course of a few days, a few weeks yea, possibility.Frank Olivas said:I am having a similar situation regarding floor sinks and trap primers, I am starting to change my mind about this. I think we should have them on floor sinks. Use "what if" situations here. What if the kitchen closes over the holidays, maybe they shutdown for a few days for repairs or renovations? Could the trap seal be evaporate?
It may not evaporate but it could get siphoned off, I've seen it happen before, nothing worse then coming in the next day to sewer gas smell.Mississippiplum said:The trap seal ain't gonna evaporate over the course of a few days, a few weeks yea, possibility.
Cooking oil will work, but RV antifreeze might be a little more user friendly on the drainage system.Screw that pour the used cooking oil down will slow the evapand
On the system yes, on the environment no.Plumbus said:Cooking oil will work, but RV antifreeze might be a little more user friendly on the drainage system.
We did a few large commercial jobs lately and something similar was required, had a real light spring in it with a plunger. not a fan of anything mechanical in drainage, so i like the ones you show here:thumbsup:this might help... http://www.trapguard.com/
Trap Guard® solves the problem of infrequently used drains by eliminating the need for a trap primer while preventing the emission of sewer gases and the backup of raw sewage into living or work areas. It is much less expensive, much more effective and much simpler to maintain than a trap primer.
