Glue and cleaner or glue and primer? I always used primer. The company Im with now gives us cleaner, no primer. I thought it was a bit strange but everyone else here says its the same thing. Any input?
That is the requirement in Oklahoma. The inspectors require it to show that you did use primer.reedplumber said:I thought it was code everywhere that purple primer had to be applied and visible on ALL glue joints...
Sent from a rotary phone.
So I guess the messier you are the faster your inspection goesplbgbiz said:That is the requirement in Oklahoma. The inspectors require it to show that you did use primer.
Sometimes. :laughing:OldSchool said:So I guess the messier you are the faster your inspection goes
Thx biz I'm glad to see I'm not the only one who knows lolplbgbiz said:That is the requirement in Oklahoma. The inspectors require it to show that you did use primer.
I heard if you pass nitrogen through it when you apply primer it works betterreedplumber said:I went to a house to clean out a tub drain the other day, the HO must have been on here reading your guys' posts because he said he did the piping and there was no primer on any of the joints, needless to say the trap came unglued. I'm not trying to be a jerk but I'm assuming that everyone here understands the importance of primer and why it is used. It's an important asset in the connection. Trust me when I say that a glue joint with primer will hold up a lot longer than one with just cleaner then glue...
Lol what a jerkOldSchool said:I heard if you pass nitrogen through it when you apply primer it works better
Just ribbing you ... Relax . LOLreedplumber said:Lol what a jerk
I had a Forrest Gump flashback when I read that... :jester:plbgbiz said:Sometimes. :laughing:
Wats upU666A said:I had a Forrest Gump flashback when I read that... :jester:
I would have a heyday if an inspector called me on that . I am the type of anal freak who strives to not have it showing. I would pretty much be kicking his ass right down the street. Inspector /failed tradesmanI thought it was code everywhere that purple primer had to be applied and visible on ALL glue joints...
Be that as it may, in OKC you would still be cutting it out if you wanted a green sticker.Fast fry said:I would have a heyday if an inspector called me on that . I am the type of anal freak who strives to not have it showing. I would pretty much be kicking his ass right down the street. Inspector /failed tradesman
Cleaner, primer, glue. easy as 1,2,3.:laughing:
Not in WI.reedplumber said:I thought it was code everywhere that purple primer had to be applied and visible on ALL glue joints...
