JW Imported Pro Press Fittings?
14K views 8 replies 9 participants last post by  skoronesa
#1 ·
So I have seen copper pro press fittings really cheap online, they are made by JW. They are sold on supplyhouse.com.
I was just wondering if anyone had experience with them or had any thoughts on buying these fittings.
I just bought a Ridgid RP 340 setup. I just spent over $4,000 in general stock fittings as well. (My supplier sells X-Press fittings, not the Viega ones).
#4 ·
I don't know about those fittings... But we have to use pro press at a certain food factory... We had problems with female adapters cracking after being pressed.. You couldn't tell till after you turned on the water... Just the slightest crack , and water was spraying every where.. We tried a fee different types, and both cracked after getting pressed.. I believe they were 1" fittings.. We use a Milwaukee pro press .. After that, if we needed a female adapter , the factory allowed us to solder that one joint... They didn't want flames or gases in the plant.
Just a heads up if you get a leak on a female adapter. Never had any problems or leaks from any other fitting , unless it didn't press properly, or batteries were dying.
#5 ·
I use only viega for pp. my personal preference and I trust their product. As far as the fpa cracks I blame the lead free laws for plumbing. I have had to be very careful with how tight I get IP connections as the LF brass is very brittle. I've even considered going back to white t-tape rather than blue monster for this reason.
