It's late and I'm probably overthinking this but....
I have a customer that purchased a grundfos comfort recirc system online and wants me to install. https://us.grundfos.com/products/find-product/comfort-pumps-up-10.html
They have a pedestal lav for the sink that is at the farthest point away from the heater. She doesn't want the crossover valve and extra hoses installed on the lav , she'd rather have them on the supply to the tub/shower. The water piping is easy to get to via an access panel in the hallway.
I have never done this, but I figure it shouldn't be a big deal...As long as I can reverse engineer the little Grundfos crossover valve ( "thermal bypass valve") in a hard pipe format (existing water supply is copper). I will not install that little plastic POS in the wall, even if there is an access panel.
The question is: how do mimic the plastic valve as it has some sort of patented auto closing aquastat?
Do you guys think a strap-on aquatstat installed on the cold to the heater would work? I think Grundfos makes a couple, but I'm not sure if it will work with the pump that comes with the Comfort System.
http://www.supplyhouse.com/Grundfos-595657-3-4-Clip-On-Thermostatic-Control-for-Grundfos-UP-Series-Circulators
http://www.supplyhouse.com/Grundfos-595444-3-4-Clip-On-Aquastat-Kit-for-UP-Series-Circulators-7-8-OD-Piping-85F-105F
The POS plastic valve is set for 93-103 degrees. The hydronic type clip on is set for 85-105, so I'm thinking this would work as long as I can get it wired into the pump.....
Fire away
Fire away
