Draining water while sweating pipe
18K views 64 replies 31 participants last post by  slate658
#1 ·
You all know the issue well I'm sure: making sure you get the water out of the pipe before sweating copper fittings together. Probably the biggest headache on some jobs for me.
If I'm having a hard time, I'll usually open up all the faucets in the house to break the vacuum, as well as breaking off the water meter, and I'll even put a shop vac on the pipe itself to drain the water. I've even used the old trick of putting bread in the pipe, but that's a last resort. I'm just too poor to afford a SweatJet haha
Do you guys have any other tricks of the trade as to how to get the job done?
#7 ·
I use 3/8" PEX. It's pretty flexible. I cut whatever length I want and stick it down the pipe to pull it out, like you grab water with a straw from a glass a water. Dump the water in my handy Folger's coffee canister I keep for all purposes and I'm good to go. A little slower than a vacuum I guess but that's what I do. Keeps me from having to duct tape it all up to the vacuum hose.
Sent from my SAMSUNG-SM-G870A using Tapatalk
#10 ·
I will blow through he pipe, use a hard supply tube if it's vertical, or wedge the pipe upwards if it's horizontal. I've never used a jet sweat and don't see a use for it personally for me. I really don't find it a big deal sweating cooper lines that have had water in them. By the time you turn off the water, drain down, cut the pipe, then you start preparing your fittings and pipe, the water is almost always gone.
#12 ·
You all know the issue well I'm sure: making sure you get the water out of the pipe before sweating copper fittings together. <snip>
Other tricks from the past ... Jelly Beans, I used many a box they worked!
#13 ·
#20 ·
This is what I have used to steam all the residual water out of a copper line under a slab. First, the shop vac. Then this fitting just in case some water droplets are still lurking.
#21 ·
I use sharkbite fitting to make the connection, then I go home, hang up my tools and never work in plumbing ever again...
kidding!
Ive never had to use the swetjet or whatever it is called but I am tempted to buy it because I end up spending a lot of time figuring out different ways to weld... often I end up welding a new valve and the trick I use often is to prepare everything, heat the pipe up and then last minute, I flux, slip on the valve and I just elevate the pipe at an angle that I have a bit of time to weld before the water continues to drip up towards where I am welding. Not sure I am explaining right. BUt yet, works great on 1/2 pipe.
#25 ·
kidding!
Sweating or welding?
#36 ·
Same here. An old timer taught me the bread trick in a pinch. He said it has to be white bread {not rye, etc.}, and to remove the crust.
I have had a steam hole leak. They are so tiny, that you almost can't even see it. But when you cup your hand around the soldered joint, you feel tiny, tiny water stream on your hand.
#34 ·
If I have a straw available, I'll use that to grab the water out of the pipe. Bigger diameter pipe, I'll stick a smaller size piece of pex in to pull it out. If I'm able to slant the pipe slightly so the water runs back the pipe, I'll do that. Other than that, I just stick my mouth on it and suck. Kekeke
#43 ·
the problem with using bread like that is it will go bad and turn rancid in the water lines and someone will get sick, then who is to blame??? also add in what if someone is gluten intolerant? and gets a glass full of dissolved bread? just remember" nothing happens till something happens"..if you want, call your insurance company and see if they will cover you for food poisoning if you use bread, is this a certified practice?..yes it sounds stupid and petty to state, but wait for the first time you get sued for something you do all the time and never had an issue..the lawyers are circling anyone and everything to see if they cant bleed you out of some $$$...you wont use any fixtures if they arent stamped or have cert #s cast into them, so why use non certified methods that could cause sickness.....ok a small piece of bread in a residential single family home doesnt have much risk if you explain and or ask the homeowner if anyone is allergic and you can flush that line clean, but the comment above after using a loaf of bread in an apartment building, that the maintenance guys are still getting bread a month later in aerators , is not good..
