21 - 40 of 48 Posts
I read somewhere that a crown-vented trap also inhibits the self-scouring action of the drain line which in turn allows build-up to collect in the vent opening. This could, theoretically, eventually block off the vent opening. I'll post something if I can locate.
I believe it has more to do with hydraulic gradient. Water will always find it's own level!
Lav crown vent? What? Dont you guys have vanity lights here their centered on the fixture so i dont understand.. im always in before electrions why would you run a vent right where a light fixture should be located. A washerbox sure.. i can see that happening kitchen sink is usually under a window? Atleast here so besides that how or why would a professional have ... Or run into this problem? As far as air admittance valves go, they are not a cheater vent for a cheater vent relies on a spring air admittance relies on atmospheri c pressure and differentials between it and the fixture its acting as a vent for hence in orxder for an air admittance valve to work their must be atleast one vent to outside air n the system for it to function correctly. A cheater vent will work, or not work regardless of outside air. Thanks seanny
Something like this: It states: "vent opening would clog resulting in an un-vented trap."
Yeah your def not a plumber.
In your area, whats the minimum distance from trap to vent?
In Ontario (might be same all across Canada) minimum distance is two waste pipe diameters.
Same here max is 6' for 1.5" and 8' for 2" 10' for 3" except water closets are 12' emergency 3" floor drains do Not require à vent.. atleast here.
Yeah so there are some differences, pretty much a foot more in the Canadian National Code. And here floor drains require a vent unless within the 6 feet of the building drain or stack. Ontario still sees floor drains as a non-emergency fixture which is total BS.
Ontario by law, must teach us Ontario code, but we get tested on the national red seal trade examination. No matter where you are in the world code is going to be different in small ways everywhere. By the time they fix problems with our testing I will already be licensed, seems a bit unfair but nothing we can really do about it.
Hack-tastically speaking, here in hack central, you can be a mile or two from the point of vent. Or in some cases, the vents are optional.
Now for licensed plumbers who follow the code, we are allowed:
Tommy plumber said:
I think you meant maximum distance......;)
No, i think he meant minimum, as per the thread title. Anything less than 2 WPØ's is considered to be crown vented.
The following user(s) wishes to thank U666A for this useful post: Mississippiplum, Plumber71, DesertOkie
We don't have a minimum from trap to vent the maximum is 5 foot
Tommy plumber said:
My bad, I forgot what thread I was posting in......:laughing:
I get around alot.
T,IFIFY... :LAUGHING:
I have a bunch of brand new one of these darn things that were in a large auction bid I won. If anyone of yuse guys want these things let me know you can have em otherwise I will throw at the end of the month
21 - 40 of 48 Posts
