Brizo Magnetic Handles
14K views 12 replies 6 participants last post by  HopeThisHelps
#1 ·
Well I should have read the instructions first, but they still don't warn you in them to not put the handle on unless you have the adapter screwed down. I put the handle on to position it, then realized I fudged up ... now I can't get the adapter out of the handle. Luckily I only messed up on one side. Gotta figure out how to remove it.
#8 ·
So far the shower and diverter valve trims have not been odd. The only kinda odd one mounted like the similar odd Delta trim that you screw that oval plate to the valve and then press and turn the escutcheon to lock some tabs into that plate. No weird magnets on the handles, but that's not saying they don't make it for some.
#13 ·
I found this thread when I was trying to replace the cartridges in my Brizo Levior bathroom faucets. Include me into the fact that there is a spline adapter that fits around the cartridge in these Brizo handles. Desplaine adapter looks like a thick gear with a fine grooved circumference at the base. there is a screw at the very top that attaches the spline adapter to the top neck of the cartridge.
In my particular case, the spine adapter model number is RP 92382. Which connects to cartridges RP100222 (hot) and RP100223 (cold).
When removing one of the handles, the entire spline adapter seems to have bonded with the interior surfaces of the handle, making the removal far more difficult than just pulling up and breaking the magnetic seal. Maybe it was glued by an unknown plumber before me. I don’t know. It sure made my afternoon difficult to figure it all out.
