Does anyone know the formula for finding the length of pipe (TRAVEL) between two 45"s? I thought I could remember it, but I was wrong. :furious:
What if its 10 in pipe 10 ft in the air in a mech room with a big piece of duct in the way ?? Tricks are great but the math is always rite and always works !!'Rando said:Finally.... I was taught the same thing except using two framing squares. no measuring, marking or math equations needed.
Tex mex, either way you need to come up with 2 measurements; a horizontal offset and a vertical offset.What if its 10 in pipe 10 ft in the air in a mech room with a big piece of duct in the way ?? Tricks are great but the math is always rite and always works !!'
you don't hold them up in the air where the pipe is!! :laughing:What if its 10 in pipe 10 ft in the air in a mech room with a big piece of duct in the way ?? Tricks are great but the math is always rite and always works !!'
That's when I use my laser folding ruler.you don't hold them up in the air where the pipe is!! :laughing:
You are still using the math, the framing squares or marking the numbers down like the other guy said just puts the equation on a surface where you can visualize it without doing the formula.
True but if you can measure for c2. Instead of using the formula to find it then its faster. I understand Thers two of sets but if you measure on a flat plane center pipe to center pipe you at removing one of those offsets from the equation just a short cut. Think about it. It works !!U666A said:Tex mex, either way you need to come up with 2 measurements; a horizontal offset and a vertical offset.
The trick with the framing squares works, you can do it with just one if you can simplify the numbers enough to make it work.
Good call.
I am thinking about it... I'm thinking I can't make any sense of that post.True but if you can measure for c2. Instead of using the formula to find it then its faster. I understand Thers two of sets but if you measure on a flat plane center pipe to center pipe you at removing one of those offsets from the equation just a short cut. Think about it. It works !!
You can lay them out on the ground and get the same measuremen,just have to have something square to measure off ofWorked for a guy who said he fired his leed plumber for trying to hold up 2, 4 inch no hub 1/8 bends and measure between them at the same time. AND was on a ladder.
Reviving an 8 year old dead thread, Ok sure why not.You can lay them out on the ground and get the same measuremen,just have to have something square to measure off of
Be glad he saved you from screwing them up lololololReviving an 8 year old dead thread, Ok sure why not.
I also worked in a sports complex building an Olympic size swimming pool and this 4th year apprentice (4th year for over 20 years who couldn't pass the exam) had a helper and both had 12" or 14" PVC 45s try to measure in between in free floating air on step ladders. He didn't know the regular offset and a rolling was alien space technology! Those fittings were around 2200$ each and had to be manufactured one at a time on a special order. I went there to calculate but the foreman came over to give me $hit because I wasn't at my post. Dumba$$es!
