***PVC PIPE AND FITTINGS***
Do you guys use pressure fittings on sump pumps, specifically 1/3hp models? Our supply house stocks pressure fittings for 1-1/4" and smaller(pvc), but for 1-1/2" and bigger it's all dwv. Sometimes they do have pressure male adapters in 1-1/2" and I will get them but most of the time they don't. I keep an m53, a zoeller check valve, and a male adapter on the van for replacing pumps. I also have a bucket of 1-1/2" dwv fittings(and a bucket of 2"). I don't bother keeping more than a couple pressure fittings as when I do replacements it's usually just the pump and check valve. Almost no one in my area uses pressure fittings for these 1/3hp sump pumps and some even use abs. Pretty much everyone here uses m53's, but some use little giants equivalent.
What do you guys do?
