In my experience these things leak for two major reasons.
1) the rubber stopper goes bad and leaks out the drain-hole underground.
2) the hydrant wasn't installed properly with a concrete support, some hack just buried it in the ground and it got kicked over and broke at the fitting connection underground.
So I usually dig it up to see if its broken or not and then go from there. Any tips on servicing these that you guys have?
