THAT IS WHAT A PRESSURE BULGED TANK LOOKS LIKE ! A CLOSED SYSTEM WITH NO EXPANSION TANK
Holy schit you're right! You just don't see the sides bowing out because the fiberglass compressed.
Even poorer which I've seen a lot was a milk jug beside the toilet. I wonder how it works!That sprayer is a poor mans bidet lololololo
So the T/P on the heater never opened up to relieve the pressure?THAT IS WHAT A PRESSURE BULGED TANK LOOKS LIKE ! A CLOSED SYSTEM WITH NO EXPANSION TANK
Why didn't the popoff valve go off before it got to the bomb stage???THAT IS WHAT A PRESSURE BULGED TANK LOOKS LIKE ! A CLOSED SYSTEM WITH NO EXPANSION TANK
Probably faulty or if it opened then water went on the floor and I've seen a few suicidal bozo's put a plug when it started to leak.Why didn't the popoff valve go off before it got to the bomb stage???
If the t&p leaks for a while it can get a buildup of rust that stops it from opening.Why didn't the popoff valve go off before it got to the bomb stage???
We had a 3yr old residential boiler we installed blow a chunk of cast iron off the back a couple years ago. The t&p had corroded shut. I don't remember which control item failed, I would guess the thermostat.
View attachment 126864 View attachment 126865
I don't want to know why I was sent to hook up a sink and this was waiting for me along with all the other materials. Never seen this before either. Feel bad for throwing it away, the landfill doesn't need this kind of crap in it. I did take the rubber washers though.
I throw away the water hoses to the dryer/washer, they aren't approved. We now have a webpage to denounce illegal fittings and such. I don't have time to waste on that though.I don't want to know why I was sent to hook up a sink and this was waiting for me along with all the other materials. Never seen this before either. Feel bad for throwing it away, the landfill doesn't need this kind of crap in it. I did take the rubber washers though.
Does it leak? No? So STFU and leave me alone!
That was the algerian the other day... He ordered me to only put a new handle on the shut off valve at the toilet. I suggested to replace the entire valve because the gaskets inside break off and you can't shut off the water and clogs a bunch of stuff. He said no way unless you do it for free. Ok no problem just a handle, still a minimum 1 hr plus full price for a valve. As for this drain not my problem and he'll call someone else when it damages the walls. Name is on my dna list and eventually blocked.Does it leak? No? So STFU and leave me alone!
