That poor 1200"Tile guy"![]()
I have seen the hole too small before where you could not quite get to the stops or screws and such. This one though really surprised me. I called and had the handyman send his new guy back to make me a 3.5" hole right away. He came over real quick and made the hole while I installed a new toilet. I showed him the screw holes and stops and cartridge retaining clip and explained it all to him so he would not do that again. I miss the handymans old guy already since he was an ok guy and did good work. I now dread the future troubles this new guy will cause me.That poor 1200
Where was the plastic valve cover specifically made for stupid tile guys?I have seen the hole too small before where you could not quite get to the stops or screws and such. This one though really surprised me. I called and had the handyman send his new guy back to make me a 3.5" hole right away. He came over real quick and made the hole while I installed a new toilet. I showed him the screw holes and stops and cartridge retaining clip and explained it all to him so he would not do that again. I miss the handymans old guy already since he was an ok guy and did good work. I now dread the future troubles this new guy will cause me.
The new guy actually also just cut and removed the tile and not the cement board and then asked me if that was good and I had to tell him that still did not help as he needed the hole cut fully open so I could actually get to the valve itself.
Here is the hole after he was done.
No where to be found when I got back to trim it out. The guy actually asked me how it was going to be sealed water tight if he made such a big holeWhere was the plastic valve cover specifically made for stupid tile guys?
Welllll there was a reason I put quotation marks around tile guy. I did also mention that it is the new guy working for a handyman company we do alot of remodels for.I don’t believe you! Tile guy would never do that! Lol!
Sometimes those are the worst!Welllll there was a reason I put quotation marks around tile guy. I did also mention that it is the new guy working for a handyman company we do alot of remodels for.
Sounds like less of a handyman and more of a bad carpenter or general contractor.Welllll there was a reason I put quotation marks around tile guy. I did also mention that it is the new guy working for a handyman company we do alot of remodels for.
Its a small company that does mostly remodel jobs. I do alot of bathroom remodels for them. Yes it does sound more like a General contractor or carpenter as such. The fact though is that they do remodels and small jobs and literally has the word handyman in their company name.Sounds like less of a handyman and more of a bad carpenter or general contractor.
I've never seen covers on on the finish, for some reason someone loves to take them off and throw them with the screws out then the hole is too small and the carriage is globed with mud and or grout. I've never truly seen a tile guy in my life or drywall guy that was smart. Maybe 1 or 2 came close otherwise if they were smart enough they would chose a trade that requires more intelligence.Where was the plastic valve cover specifically made for stupid tile guys?
A great mix of ABS & PVC a real handymans delight !
Yes and no.Busy week Skoro? Those are some good ones!
