Can we have a thread for these please? If you look close you can see the wet cardboard gasket between the rubber and sink. Nice
But why else would they put that cardboard ring on the strainer between the gasket and the nut, if it wasnt ment to be installed..........:laughing:Can we have a thread for these please? If you look close you can see the wet cardboard gasket between the rubber and sink. Nice
they need more wax.........Below that tee...
House was full of hackery...they need more wax.........Below that tee....gota love that old cast iron pipe.........almost as bad as the old galvanized that splits on the seems............![]()
One more from tonight.
Look at the trap. The waste outlet is higher than the continuous waste. This is the second one in this apartment building I've come across. We fixed the last one and these tenets move out at the end of the month. I just needed to get it draining till then.Looks like something i'd never do but I don't see anything illegal unless there's a garbage disposal to the left. I hate tubular pipe, it's for handy hacks
And brother-in-law gets to fix it for freeFrom my sister in law's house
This one was a bit hairy to cable. Whatever kind of hub they used to connect the pic and galvanized let it flop around in the wall. Thought I was going to loose it in the wall.
When drain cleaning at this place you have a 50/50% chance of knocking a hole in the bottom of the drain.
