1 - 20 of 24 Posts
Pro Press is great in commercial for capping lines or installing cutoff valves. I don't prefer it for general piping though. I like old school soldering.
We have it in our shop, it will save time when you need to repair larger copper lines when time is short.
Reactions: JK949
We use it when allowed. Code allows it. A lot of architects do not.
What's the full disclosure on their reasoning?
I'd use the stuff if it wasn't so damn expensive. What is that, like 4 grand worth of fittings there? :laughing:
I replaced a water heater today and for the first time, I needed a get-swet, or propress ball valve.
The trick I "hope" got it to solder was heating the pipe an inch above the socket of the ball valve really high and it took the solder as water was slowly dripping out of the valve.
I pray that the solder didn't ring around the edge of that brass socket. :eek: That's not a good solder joint. It did however liquify all around pretty well, didn't want to build up, like it wasn't pulling in.
The trick I "hope" got it solder was heating the pipe an inch above the socket of the ball valve really high and it took the solder as water was slowly dripping out of the valve.
They are architects. They never give a reason:furious:
Fittings are pretty consistently 4x sweat.
I had a water service the other day I cut the end off of the 1" to the house. Meter would NOT shut-off. Curb box was god knows where. I cut that baby off. Had it shooting full bore. Pressed a 1" PP ball valve on and shut-it off.:thumbup:
By the way, the fitting was in a vault. I would never bury PP.
I don't like the deformity it does to the pipes, beside that, it is a quick fix, I did like that it made for less down time.
Most sizes don't deform too bad except, the 2". It looks like chit after pressing. Just down-right ugly.
Yep Dat be Da one....
Discussion Starter · #10 ·
Ferguson has been selling us the fittings for a little over double sweat price. If you figure the time it takes to silphos 3 or 4 4" joints compared to about 20 seconds per PP joint it starts to save a lot of time. Not to mention on repairs where down time is a serious issue and you can't quite get that pesky stream of water off. They do have their place, not always, but sometimes.
In the high rises i've been working on in Chicago, we've been pro-pressing the risers. It seem to hold up good. the time we have had leaks its usually because some one did'nt push the pipe all the way in.
Gotta admit, Pro-Press has its place fo sho !!
Pro Press
On my last job the boss brought over the pro press. I was horrified as easily fitted and pressed a hallway in a day, when i could have usually eaten up a week soldering and pollishing and making it pretty:cry:
what am i going to do with the rest of the week?
We had a lengthy discussion on it a while back. Search for it and give us your take.
It is Tuesday. Bring on the PP dead horse:laughing:
Abbra Kadabbra
1 - 20 of 24 Posts
