Putting a water heater on a stand
Or leaving it on the ground.
:whistling2:I like gathering opinions. :whistling2:
Safer from WHAT?Putting a water heater on a stand
Safer from WHAT?
What is your point????
Have you seen the experiments done on both applications...the videos?
One is far more destructive.
Link?
Exactly....The room fills up 18" of fumes then it gets set off. I posted this same theory in thread couple months ago. More fuel=bigger explosion...simple.No link, but there is a video on a CD I'm trying to get from this guy.
The video proves that the application of the stand is far more disasterous.
Reason:
2 mock tests were done in a concrete vault. Simulated gas can being knocked over. Oil based paint is also a known flammable.
When the water heater at ground level ignited the flammable liquid, the intensity of the flames were minor in regards to the situation.
When the water heater at 18" on the stand?
Keep in mind that there was a buildup of fumes that had to crest to 18" to find that source of ignition. When the ignition took place, the intensity and explosion was far greater, and that vault was a massive fireball when it ignited. Basic thinking implies far more percentage of fumes before ignition point.
This fellow told me they that they was trying to lobby to get rid of those stands, given the testing that was done that proved the % of flammability was increased by raising the source of ignition, and the result was far greater damage/destruction.
What was the area of the concrete vault? How airtight was it?
