1 - 5 of 5 Posts
I need a small SS heat exchanger for heating RO/DI water. Heating water will be flowing at about 2-2.5 gpm at 160F and heated water will be flowing at about 1.5 gpm with a target temperature of 140F.
Does anyone have any recommendations? I need a heat exchanger made of 316 stainless steel but it needs to be large enough and efficient enough to get to my target temp/flow rate.
Another source would be Grainger there online you know.
We use mostly Alfa Laval hexes where I work. You should be able to find a rep from Alfa's web site. You'll need to be more specific when you talk to them, the will need to know heat transfer rates, hot side flow and temp, cold side flow and temp, as well as allowable pressure drop.
Registered User
Introduction Requested
An intro is requested from all new members. In case you missed it, here is the link. http://www.plumbingzone.com/f3/.
__________________
1 - 5 of 5 Posts
