21 - 40 of 55 Posts
Delta Multi choice, knock out the shower restrictor for full flow. Moen next but machined ports are only so big . No big thing unless you have a divertor valve after the mixing valve and want to run more than one shower head. The Delta multi choice has better flow. Both cartridges have their issues. Does anyone else use a Moen tub / shower faucet for just a shower stall. I connect the shower head to the port for the tub spout and cap the port that went to the shower, much better flow but a pain to construct. Delta much easier.
Why’s it a pain to construct? Just put it in upside down. Moentrolls and positemp body’s don’t care what side you’re feeding hot and cold from.
I’ve only met one moen cartridge so far I couldn’t remove and it was a 50ish year old brass one. I Use the puller on every one of them and never have an issue.
I do a mix off 304 bodies and Positemps if I’m picking somthing. The majority of bodies I do wind up being Waterworks, California Faucets, Sherril Wagner or some one off expensive brand. If people ask me for advice on a high end brand I try to steer them to Rohl.
Il Lic. Plumber
But then the cartridge,trim and handle would be upside down .
I could flip the cartridge, but the bump on the posi temp would be on the bottom and the trim would have to be upside down. Put the handle assembly on upside-downx this may work. Never know what an old dog may learn on here . Think outside the box
Certified Smart Ass
Discussion Starter · #25 ·
You can completely flip the cartridge upside down and rotate the stem. It'll work fine. I've had to do it several times (just dealing with what's in front of me, you know how it goes.)
Like Martin, we get Waterworks and Dornbracht and Vola. I don't like the heavy lifting involved with Vola, but their tech guy, John Kamuda, is great. Fortunately Waterworks and Dornbracht have a few good tech people as well. If we're lucky, we get an occasional Hans Grohe iBox, a Rohl or a Grohe. I like Grohe and Rohl because I have a good relationship with their reps. Once in a while a Kohler comes our way. Haven't dealt with Moen or Delta for decades.
Plumbing since 1974
Plumbing and light HVAC
The puller can't help if the Positemp's brass stem is broken (dealt with two of them just in past month).
That really sucks. I've never had that happen. I've had the center stem pull out and needed to use a spiral extractor for the outer piece though.
Plumbing Parts Manufacturing
I am not sure I even want to post this but....
phuk it here goes nothing....
there is a superior puller out there...
I have watched you guys brutalize each other, I can only imagine what you are going to say to me.
.................there is a superior puller out there...
I can do the same with my chrome puller using a piece of pipe. If the outer piece gets stuck I have a whole extractor set.
If I was just starting out I'd probably get your ona puller, but given I have the old chrome one and a bunch of other extractors I've never had an issue and don't think I ever will.
Reactions: bawalter
........................I have watched you guys brutalize each other, I can only imagine what you are going to say to me.
The glasses make you look like a nerd......lolz
Reactions: sparky and bawalter
Only Moen and I have some left over delta. Delta is on the way out, cartridge are at 120$ plus mark up and people get angry I'm robbing them.
Moen: I haven't had too many problems getting tub/shower cartridges out with a puller. For roman tubs however they are a nightmare.
Yes the delta cartridges are high,but you can go to Lowe's and buy them for 48.00 bucks,a delta rep swore to me that they are the same faucets in big box stores and plumbing supply houses for us pros,I dont know for sure and have no way of verifying what he said
I never thought nothing about this,so the tub port is a larger opening allowing more flow,correct???that would be some crazy faucet building there lolololol
21 - 40 of 55 Posts
