What type of Glue
  • Super Slow Set - Red Can Oatey
    Votes: 0 0.0%
  • Slow Set - Brown Can Oatey
    Votes: 2 7.7%
  • Fast Set - Green Can Oatey
    Votes: 8 30.8%
  • Fast Set - Dark Green Can Oatey
    Votes: 1 3.8%
  • Write in - Other Brand
    Votes: 10 38.5%
  • Elmer's Wood Glue
    Votes: 5 19.2%
1 - 20 of 22 Posts
I use the fast set glue, bright green cans of glue from Oatey.
It's a pain to use the slower setting glue...I simply just do not need that "time" to rethink a connection.
Temperatures play a heavy role in those slower setting glues as well.
Manufacturers Glue!
I always, always, always try and use the manufacturer of the pipe's glue. For example, with IPEX PVC which is the strong majority of the PVC & CPVC pipe I buy at the wholesaler, I like to use their Xirtec PVC Primer & Glue (medium or heavy bodied doesn't matter to me but I usually end up with heavy bodied). For non-pressure applications i.e. condensate drains I prefer to use the one step wet/dry.
Because the definition of "PVC" is fairly wide & varied in the codes/standards from what I have been told, it is a highly recommended practice to use the manufacturers glue, and if you don't believe me, contact the manufacturer of the PVC pipe & fittings you install and talk to them about it.
IPEX SYS. 15 and SCH. 40 glues
Senior Moment
Hmmmm so far over 20% of the plumbers here use Elmers, interesting.....:laughing:
Glue? You're supposed to glue the stuff? Who knew?:laughing:
I seen duct tape
I seen mighty putty
I seen silicone
I seen mortar mix
I seen inner tube and hose clamps
ive been seeing more inspected jobs lately were the plumber used the rain or shine glue....ive always thought it wasnt for pvc dwv but what do i know
Lego Expert
Irrigation guys are the only ones I see using blue glue. Did they purple prime the pipe first?
1 - 20 of 22 Posts
