61 - 80 of 85 Posts
· Registered
You should mount a fake lock bracket and a lock on it…….see how long it takes to get cut off. 🤣
Might as well mount several, slow them down with a few Red Herrings!
· Registered
Discussion Starter · #63 ·
Somone should make a lock that blows out pepper spray if it’s cut. 🤣. Probably be a liability.
Or Yiu could design a system if the door is opened without disabling the pepper spray would trigger it…..still would probably be a liability. Boobie trap is illegal. Fun to think about tho. I hate a thief.
Just have the hole already dug……
· Registered
They do. There's also one called the "SkunkLock", same idea but smelly.
· Registered
I got tired of using tool bags and started to use this packout setup I made myself. Always organized and easy to tell if I am missing a tool before packing up. It's the basic set that goes in on all jobs and does like 95% of all work. The messy box is most of my specialty tools that i dont use too much so I don't want to bring them in and just grab the tool I need from the box on the van. This exact setup has served me well for 3 years now. Even use it to stand on when I need an extra inch or two. View attachment 137322 View attachment 137323
· Registered
Blue Paint Rectangle Orange Art paint
· Registered
......And all of his victims were put in barrels of acid along with animal parts to stop any identification.....
· Registered
Oh please, it's not like I'm freaky organized. It's just about the only nicely organized thing in my van. You should see the mess I have in the back.
Sent from my SM-S906U using Tapatalk
Yes, I know, I've seen the mess in your rear.....
  • Haha
· Registered
I like the setup but it seems bulky and as if the cases add unnecessary weight.
Of the guys who I work with who use packouts, it’s usually the wheeled box with power tools and a medium box with hand tools. Both cases a mess filled to the top and need Tetris skills to close.
· Premium Member
I got tired of using tool bags and started to use this packout setup I made myself. Always organized and easy to tell if I am missing a tool before packing up. It's the basic set that goes in on all jobs and does like 95% of all work. The messy box is most of my specialty tools that i dont use too much so I don't want to bring them in and just grab the tool I need from the box on the van. This exact setup has served me well for 3 years now. Even use it to stand on when I need an extra inch or two. View attachment 137325
That's a little much even for my OCD ass. Haha
Make sure your tools are completely dry or I bet they'll rust all to hell with a quickness in that foam.
· Registered
Just spray them with some WD40 from time to time. Take the foam out and lay a cotton rag down then put the foam back. The rag will hold the oil and keep everything coated perfectly for quite a while. I have a nylon toolbag with plastic bottom that I have done this with, works great. I keep all my specialty tools in it such as big basin wrench, smart dumbell, spud wrenches, drill bit box, tile bits, etc.
For multibit screw drivers stick a half cotton ball in the handle and add oil. Put just a touch of cotton in the actual bit holder with oil.
  • Haha
Reactions: TerryTotoSucks
· Registered
Discussion Starter · #79 ·
· Registered
Service Plumbing
Here's my bag. An Estwing tool backpack. poly bottom so it's water/sewage/oil proof.
Zippers broke so I attached nylon straps and buckles. Quick to open and close.
I saw another backpack that is more rigid and stays open so I added Luan side supports.
Plenty of duck tape in certain areas
I think this bag will last another year .
I try to keep the weight down so only tools I use every day.
61 - 80 of 85 Posts
