1 - 20 of 24 Posts
I just installed an A.O.Smith 52 gal elec. heater. When I powered it up, the upper element began drawing power and a few seconds later it began squealing loudly. I've never experienced this before. I called the factory rep and he explained what the problem might be. Any service techs. got the answer?
Illinois Licensed Plumber
My first guess would have been when you filled the tank, you did not bleed the air out of the tank, so the upper element was running dry due to the trapped air in the tank. Other than that wrong voltage to the new heater could be an issue.
I am quite sure SongDog knows to bleed the system before powering it up. I never had this happen to me and am waiting to see what others have to say.
Shrink wrap was still stuck to the element, and was not all removed, once fired up it tries to eliminate the wrap by burning it off, this making that squealing sound.
Discussion Starter #5
Jeez, Gimmee a little credit. Ive been doin' this for almost 30 yr.s
Water Whisperer
Its the Swine flu?
There's a hole in the element? Change the element.
I did not mean any offense, I am sorry. Its the only thing I could think of as to the issue.
Maybe the factory installed the wrong elements.
LeMarr Plumbing, Inc.
You mean that you should bleed the air out before turning on power???:laughing:
For all this time, I was doing it backwards.:thumbsup:
In Christ,
Song Dog
I got nothin',,,,,,,,, never heard this before . Now I'm curious
In Christ,
Song Dog
Sorry SongDog, I was reading one of your posts earlier and meant to say Hyper Piper, but put your name instead! Oh well, engaging the fingers before the brain I guess:rolleyes:
I will forgive ya, Ole' Buddy:thumbsup:
I'm with Herk on this. I have never heard it before but it makes since to me.
OR it could be low on anti-squeal upper element fluid.
In Christ,
Song Dog
Maybe, but if the upper element anti-squeal fluid does not meet UPC code requirements then he will have to replace the contaminated elements and the fluid too.
master of disaster
change the anti squeal fluid from 10wgt. to 50wgt. fluid, it will stop the squeal but it will take longer to heat up . works every time!
Ok so tell us what it was.
1 - 20 of 24 Posts
