Why do you switch to threaded adapters instead of going straight from copper to PEX?
The leak was above the slab. Why did the floor have to be broken?
The first problem with epoxy lining is that it costs as much or more than a pex repipe in most cases.What's your opinion on E-Pipe in a case like that to avoid future leaks?
A 4th problem is it limits your remodel path.The first problem with epoxy lining is that it costs as much or more than a pex repipe in most cases.
The second problem is that it can actually cause leaks during the pipe cleaning process before the epoxy is injected.
The 3rd problem is that the epoxy will de-laminate from the pipe if someone unwittingly solders onto it later on. This could potentially turn into a nightmare scenario where you have trapped pieces of epoxy under the slab that are virtually un-locatable in soft copper systems.
Soft solder is fine. Pex must be sleeved through concrete.Nice video....
quick questions ,
what is your local code for sweating copper under the slab ?
does it have to be silver brazed ?
also, do the pex and or adapters require sleeving before being reburied..?
thanks..
and again
nice video
:thumbup:
Shiot happens :laughing:Truthfully? I let my stock run out on pex by sweat adapters :laughing:.
I know, I slacked :sweatdrop:
One of my customers got a leaking 1/2" underground copper kitchen line epoxy lined (by someone else - I was too busy to look at it). After the repair the flow on the repaired line was so pathetic that they ended up taking the floor out and replacing both lines all the way to the sink.The first problem with epoxy lining is that it costs as much or more than a pex repipe in most cases.
Also, I'm not convinced that the epoxy won't start flaking off in areas of the system where the pipes were not cleaned properly. There is no way to know for sure that the pipes have all been cleaned properly as you cannot inspect them like you can with drain pipes.
In a nut shell, it's a very expensive gamble.
Because you ARE actually that bored
slab leak in lakeland florida - YouTube
