On call, slab leak, was gone for a few hours, back there tomorrow, leak detectors to show up, so I won't be around tomorrow, had to shut complex down all together tonight.
Done, thank goodness the concrete cutting company works on weekend emergencies, or I'd still be there, never did see the problem spot but is was beneath the footing, did a slight reroute, 6.25 hrs each with a helper. Forgot to get pictures. American Leak Detectors sure to charge allot on a Sunday, but was will worth it. We have reason to believe a capped line came apart under the slab.
You ended up going anyways. good job, bet you glad it is over, and it opened your day up for tomorrow :thumbup:
Commission?When I said I would not be around I meant on here, yes glad it's done, all in all a made near $600 off the commission.
Not for RR but the company I work for pays a commission.
