Today! One of my builders I do work for aunts calls me to come look at her drain. (keep backing up) So I go out there thinking no problem. I get there and water is standing in here house
(ranch on slab) SO I go out side to check the clean out. Water came gushing out when I removed the cap.
. I then go rent a sewer machine (electric eel with 75' cable and root cutting blade) I shove the line down the hole got it to bend (hope to be going the right direction (how can you tell if your going the right way)? Well back to my story: I shoved it out 70' with no blockage. So I thought I was going into the house? So I pulled it back out and try to revert it the other way. got about 25-35ft and ran into something. The lady said it sounded like I was under her house. :whistling2: After trying to
with this for 2-3 hrs I told her to call a drain specialist ( A company I usually refer people to anyways do to not having equipment)
I told her upfront I usually don't do the drain cleaning part. I was afraid I was hitting her toilet from the bottom or something?????
SO for future referance can you guys share some helpful hint on directing the direction of the tip? or anyother info would be great! :thumbup:
