@skoronesa
Do you know where I can find some Bibb screw taps that are in screwdriver form that the taps fit into the hollow handle for storage ?
craftsman use to make them. I can’t find one like it anywhere.
I have the handle type tap holders but would like something smaller like I use to have along with tap storage onboard.
I also have a screwdriver style handle that holds those size taps in the shaft, it uses a set screw, but the handle is solid. I also have the Klein handle with a reversible bit that has 3 stepped sizes on each end, of course that's no good for a blind hole. The Klein version has replaceable bits(Set screw), you could replace the stepped taps with standard ones, hollow out the handle, and use a pipe plug or cap. Unfortunately they changed it so the tap bit is no longer held in with a set screw, you'd have to find an old model to modify.
Klein Tools Multi-Bit Tap Tool Driver increases your job speed by combining your taps and drivers in one tool. Available in six common tap sizes, the tool comes with four screwdriver tips and three nut driver sizes. The large Cushion-Grip™ handle provides greater torque and comfort. Work smarter...
www.kleintools.com
I can't say I've ever seen the craftsman version you speak of. You could take the shaft from a solid handle type and attach it to a handle with storage. There's no shortage of screwdrivers with storage handles, just need to find one that takes 2" bits so the taps don't rattle on each other.
I will keep my out open for what you speak of.
