1241 - 1260 of 1287 Posts
· I aint CPV see in it?
Building Wood Gas Tints and shades Pollution
Wood Bedrock Landscape Building material Soil
Another little commercial kitchen rough. It’s a small space and not a lot of room. 2” backflow I replaced in south GA this afternoon at a McDonald’s. Put a Union on your backflows guys. I had sweat that 2” male on with a plain ass turbo torch. Supply house in the town didn’t have a 2” press male. Life sucks sometimes.
· Registered
Discussion Starter · #1,243 ·
Use two torches in that situation if you don’t have the proper tip. That’s what I use to do before I bought the big tip.
· Registered
Did you have to bid the top job??
· Registered
Discussion Starter · #1,251 ·
Today I ripped out some 1” pvc water pipe in an outside storage area that houses the water main and connection to the homes copper manifold.
I added a 40gal electric heater for a shower in the same room.
Used stainless crimp fittings and Rehau pex to replace all that pvc.
Replaced the heat trap steel nipples with 316L stainless nipples on the box store Rheem.
Installed a full port drain. Upgraded the elements to 5500 watt, made a note on the rating plate.
· Reverend, R.S.E., Master Plumber
Nice Head, what’s in the bag?
-Re&re a kitchen faucet + valves,
-Flange repair and set new toilet,
-auger W/C and remove “pig hoof”(dog treat),
-re&re vanity faucet and PO
Safety glove Gesture Thumb Wood Nail
· Registered
Discussion Starter · #1,254 ·
1st call today is to high loop a dishwasher hose. House is being sold and home inspector caught it. Contract says all problems must be corrected by licensed plumber. 😬
2nd call is replace a lavatory faucet.
3rd is to replace a dishwasher
4th is to replace a dishwasher
Easy $1,000 day. ✌
· Registered
Reactions: sparky
Easy $1,000 day. ✌
That 1st call sounds like a call back to me Terrance.
· Registered
Discussion Starter · #1,259 ·
Todays service calls :
1. Restaurant has a leak on the lavatory drain in the womens restroom
2. Install parts in a Zurn flushmate toilet
3. Replace toilet parts
4. Replace toilet parts.
$600-700 day and I’ll be done by lunch.
I love my job ❤
· Registered
It’s a flush handle for a Zurn two piece toilet with the flushmate tank.
Water was dripping out of the flush handle onto the floor. The actual lever you press has been removed in order to remove the module from the tank.
Go
-re&re vanity faucet and PO View attachment 137871
do you have your boots off and working in sock feet???? If so I would never ever do that in other peoples homes/buildings because you never know what you are stepping in and pet hair gets all over your socks, I wear steel toe flip flops if boots have to be removed
