Well don't you just feel silly!........ brand new crimper on the shelf for years and years. .....................It works perfect for PEX. Same size exactly.
............... then Kiteck went belly up and left everyone
holding the bag of excretement......
I agree, but at that time our supply house was pushing that junk and the brother -in-law hadShould have used sweat copper![]()
I am really interested to see how pex holds up. Obviously rodents will be and have been an issue already. And there have been some cases of uponor/wirsbo getting brittle. We use viega and I have yet to hear of any systemic issues BUT that could all change in a decade.I agree, but at that time our supply house was pushing that junk and the brother -in-law had
a hard on to try the stuff.....we only use wirsbo pex now days.
Pex here for +-30 years, pipe and fittings are fine. Now we use plastic fittings.I am really interested to see how pex holds up. Obviously rodents will be and have been an issue already. And there have been some cases of uponor/wirsbo getting brittle. We use viega and I have yet to hear of any systemic issues BUT that could all change in a decade.
I think pex/polyethylene will be fine long term. We've used it for well pump drops and main lines from the well/street for decades and it's held up great. Especially the thicker stuff, no issues there.
It's the fittings for pex I worry about. Brass/bronze corrodes, and plastic gets brittle.
Why not just install simple spin down filters after the softeners? Even a wye strainer would be better than nothing................At this time we are having fits with water softener resin going bad at faster rates due to the chlorine and other chemicals
I made a thread about rotting copper fittings about 5 years ago and Redwood went ballistic
about how I was making temp repairs on the stuff .... We had a little spat over it , then he left the forum....
Most of the time when I see copper dwv fail it's the uric acid when they don't flush after peeing. I have temp repaired some drains too, depends on the situation. Usually it's just until we can come back to replace it. Sometimes I solder the pinhole shut, other times it's silicone, red rainbow, and a hose clamp. I always keep a good selection of hose clamps on the van.
I was suggesting you put a filter AFTER the softener in case the resin failed it wouldn't get to the rest of the house.You can install an activated carbon filter if the customer wants one, but they are not free and
you cannot convince people that it will extend the life of the water softener... I dont know what
you mean by a wye strainer..??.. The small spin down carbon filters have to be changed out every so often
and most folks are simply too incompetent or lazy to do this task ....I cant make them , only advise ....
That will not solve the problem, it only will end up shutting down theI was suggesting you put a filter AFTER the softener in case the resin failed it wouldn't get to the rest of the house.
A wye strainer is a fitting most commonly used on heating systems before sensitive components to prevent rust/sediment from damaging them. They're also handy when a whole house is piped with galv, you can put them before the stops for a faucet so it doesn't get damaged.
