Apparently some of you out there do not know this:
13-612.AB.3.4 Solar water heating systems. Solar systems for domestic hot water production are rated by the annual solar energy factor of the system. The solar energy factor of a system shall be determined from the Florida Solar Energy Center Directory of Certified Solar Systems. Solar collectors shall be tested in accordance with ISO Standard 9806, Test Methods for Solar Collectors, and SRCC Standard TM-1, Solar Domestic Hot Water System and Component Test Protocol. Collectors in installed solar water heating systems should meet the following criteria:
1. Be installed with a tilt angle between 10 degrees and 40 degrees of the horizontal; and
2. Be installed at an orientation within 45 degrees of true south.
So the next time I roll up to a HOs house and see a collector flush mounted on a North, East or West facing roof deck I am calling code enforcement! This crap is getting old! :furious:
Florida solar water heater, Florida solar water heating, solar water heater, solar domestic water heater, solar collector mounting, solar collector orientation, solar panel orientation, collector azimuth
