Yes
You will just have to learn to live with the drip or remove entire faucetYou
I have a Moen, single handle showered faucet. It is a thin wall installation. The retaining plate is preventing me from removing the retaining ring so I can replace the cartridge.
The thin wall install plate cannot be pushed back Any ideas on how I can access the retaining pin?
Appreciate anyone's help on this. View attachment 133984
You really should find a new master. Your current one is failing you.You
Don't forget the "Made with 100% recycled ocean plastic" stamp!I remember when they had the white plastic mud guard. Then they were black for a while. Now they're green. I wonder what color theyll be next. Grey. That's it. I believe they will be grey. Change my mind.
I was gonna suggest getting some monofilament line,properly tie a fish hook on the line,remove shower head and nipple the "fish" the hook and line down from shower head and hook the pinCut a hole in the wall behind the valve,to access the pin.
heheheh..I was gonna suggest getting some monofilament line,properly tie a fish hook on the line,remove shower head and nipple the "fish" the hook and line down from shower head and hook the pin
Grohe is grey, Moen is white, Kohler is black, and Symmons is green.I remember when they had the white plastic mud guard. Then they were black for a while. Now they're green. I wonder what color theyll be next. Grey. That's it. I believe they will be grey. Change my mind.
No sir. I assure you moen switched at some point to black and it stayed black for quite a while. And now they’re green.Grohe is grey, Moen is white, Kohler is black, and Symmons is green.
I’ve seen a few chewed up cartridges/stems, where the homeowner didn’t know about the “pin”… heheh.No sir. I assure you moen switched at some point to black and it stayed black for quite a while. And now they’re green.
but to the OP, I can get that clip out as is, and hope to bell I don’t drop it in the process.
Anyone ever come across one with the HO put a pipe wrench on the valve body (cartridge housing) and bend and twist the ever loving sh!t out of it? I have. I had no words.
It's been available for about a month a half on all forums that use this engine.Helpful?! When did that happen?! That could get dangerous to the illiterate that join here!
Haven’t noticed. This is the only forum I use now.…It's been available for about a month a half on all forums that use this engine.
