Given three guesses it would be cost, cost, and cost.
See post#18 this threadI dont work with anything this involved, but my question is if I used one of those 3 or 4 inch fernco fittings on a line in
someones basement I would be worried about them sagging over time.....
I have seen them move and sag many times....
How come no hub clamps with full SS bands on them not used in this application????
Why would fernco fittings without full SS bands on them be passable and ok on work like you are doing???
are you putting some kind of leg or support under each one of them?
It all looks real good to me, I just did not think fernco fittings were kosher in commercial work
Those Fernco's are WRONG. They should not be there. Pvc/ci adapters and no hub couplings are correct. I bet you don't put a 10' head on those connections.
Now the question arises, does the lowly apprentice make a mention of this Fernco issue to his bossVery nice work. I wish we could use pvc on commercial jobs in my state but I am ok with not being able to use ferncos. I completely understand that you’d probably prefer not to use them too but if that’s what the boss orders you don’t have a choice.
The walls should never take the load of a properly mounted carrier fixture. The carrier is bolted to the floor and the 3/4 rods should have nuts and washers between the wall and the fixture carrying the load.
Depending on whether or not the brand we supplied meets the c1461 standard, I reason that they are actually not specifically prohibited, but given the spirit of the rest of the sections regarding mechanical couplings I tend to agree with you none the less.Those Fernco's are WRONG. They should not be there. Pvc/ci adapters and no hub couplings are correct. I bet you don't put a 10' head on those connections.
Well, just dont be the guy to ask the inspectors about this issue...And upon rereading the above specs both 1460 and 1461 call for shields, meaning that they are indeed wrong regardless of sag, support, or other stipulations.
I always like to throw a liberal amount of pro dope on the inside of every fernco fitting I have to install....The short answer is that ferncos have no place in new construction. The money you save using a fernco over a husky band or no-hub is lost because you need to support both sides of a fernco so it doesn't sag, this almost always means at least one hanger.
Even in a vertical situation, where you're almost always using a fernco to transition from plastic to cast iron, ferncos aren't ideal because over time they squeeze out thinner and won't be making a good seal when rust accumulates. Almost every fernco I've taken off cast iron had rust flakes stuck in the joint.
Don't get me wrong, I use ferncos alot for drain cleaning, almost as often as I use a no-hub, but they're always supported by at least some loops of hanging strap. Hanging strap is a bit wanky for a brand new building. For the 100yr old houses I work in, a fernco and strap is usually going to outlast the rest of the plumbing and often the homeowner.
When we want a fernco to be more permanent we will prime the pipe and give it ~30 seconds to dry, then put the fernco on. It bonds just enough. When you need to remove it, make a slice longways using a razor, it will peel right off leaving almost nothing behind.I always like to throw a liberal amount of pro dope on the inside of every fernco fitting I have to install....
I also like to grease up the pipe real good too.... They DO get loose over time and I have had to tighten down a few
I know the pipe dope will lube up , fill the gaps and seal everything extra well,
and it will most likely last for the rest of my lifetime anyway....
I have used PVC glue on them before and that basically makes it impossible to removeWhen we want a fernco to be more permanent we will prime the pipe and give it ~30 seconds to dry, then put the fernco on. It bonds just enough. When you need to remove it, make a slice longways using a razor, it will peel right off leaving almost nothing behind.
Doesn't work with no-hubs because they are made from Neoprene.
I’m still learning how to effective use and understand my code book but here is what I mentioned earlier about supports. This is an addendum in Allegheny county :
it’s confusing because I don’t see any standard mentioned for any unshielded coupling above ground, but here it shows a lean in that direction. Sorry for the barrage of responses but this is something that piqued my interest both at school and in the field in practice. Yet I could never get a definitive answer on the subject.
Our inspectors have never had a problem with the methods we use just to clarify, but I’m always looking to have the knowledge to do it right, do it better, and understanding some of the reasoning why as well.
Back in the 80’s I fabbed up some no hub carrier hospital groups at the shop. Both soil and water piping and then transported them to the job. We used a no hub sealant made by Gaco. It really solidified the joints for transport. That and some strategically placed unistrut temporary braces. They were about 20’ long made in two sections. I see there is a similar product out there from Black Swan.When we want a fernco to be more permanent we will prime the pipe and give it ~30 seconds to dry, then put the fernco on. It bonds just enough. When you need to remove it, make a slice longways using a razor, it will peel right off leaving almost nothing behind.
