I like the submersible for its simplicity, connect, drop and run. While I prefer the Jet Pump, it does however take a bit more finesse to get it right. There seems to be so many things to get right with them, like if there is a grain of dirt stuck in the jet valve it will keep it from pumping up pressure.
I also like that the newer ones have a switch to convert from 110 to 220 where as the older ones you had to switch the wires around.
