You need to solder it, not braze. Use Silvabrite 100 or any other silver bearing solder. I would also suggest a silver bearing tinning flux such as Oatey's. The most important part is not overheating the stainless and causing the surface to rust. It's like soldering to a copper plated Holdrite bracket but even more finicky. Heat your coupling first and you'll be fine.
To be honest, if you're uncomfortable with this you may want to just rent a propress tool or use a compression fitting. I've soldered to the stuff in crawlspaces and basement ceilings, not sure I'd be okay burying it in a wall. You can always tin the end of the pipe first and then put your coupling on.
For a brief period in time copper was more expensive than stainless due to the housing boom. Look up "TuboTron" Stainless Steel pipe.
