1 - 6 of 6 Posts
Part # 44250700
Lists for $133.00 on www.SpartanTool.com and out the door it's probably going to $155.00 with shipping.
This is a must have for anyone on this machine. 5-10 pounds in each tire, nearly flat is the way to go. Shoe Booties fit nicely over the tires without much effort.
The nearly flat tires allows for tires, not your upper body to take the shock of going up and down steps.
I will say...getting used to those nearly flat tires is tricky but after awhile you'll see that it is making the use of the equipment a far better application,
especially if you spent years with those hard tires taking every bump or step along the way.
Ha! Looks like the ones on my machine. And yes, I always kept them under inflated. It does seem to be smoother going down stairs too.
1 - 6 of 6 Posts
