1 - 20 of 25 Posts
· Registered
Plumbing Designer
Hey all, apologies for not completing this before posting - and many thanks for the advice I received!
So I'm a Gemini, like long walks on the beach, turn-on's include puppies and butterflies, turn-off's include mean people and alarm clocks. Right now I'm wearing... CRAP! Wrong forum, sorry about that... ;)
Actually I'm not a "real" plumber, I'm a plumbing designer (AKA Turdherder) by trade. Been at it since the late 80's when my career as a concrete finisher was cut short by my apparently girlie knees. I needed to find something else so I hired on at a place as a drafter and gradually learned the basics (stink up, poop down). A couple years later I had "hot on the left, cold on the right" down pat so I was off and running... ;) I'm not an engineer, and confidentially I can't stand most of them. They look at our trade like it's something stuck to the bottom of your shoe until they royally screw something up and need your help fixing it.
Anyway, most of my career has been in healthcare (lots of med gas work) but I've had the opportunity to create drawings that get laughed at by plumbers on most types of projects - commercial, airports, prisons, high rise, etc.
In all seriousness, I've learned a ton over the years by listening to guys like you in the field, and not being afraid to ask the poor guy trying to build what I designed what he thought of the drawings, and what I could do better. Unfortunately, it seems like the new crop of snot-nosed kids seem to look down on that approach since they already know everything. I hope you guys give 'em hell. 😁
· Registered
RETIRED Pornstar, Service Plumber
I'm fine with him being here so long as he corrects himself. "Turdherder" is a euphamism for one who snakes drains, as in herding the turds in the correct direction when they go astray. In this livestock analogy he's just the fencing designer, deciding borders.
· I aint CPV see in it?
Plumbing
Hey he checked ego right off the bat, and he’s not here asking how to remove a shower handle or fix a leaking tub drain. I actually found his first post about the pitting of copper interesting. Not something I’ve really seen before and enjoyed learning the possibilities. Valuable information, let him ride. He’s good with me.
· Registered
He said he’s not a real plumber in his intro. Is PZ going woke to let anyone who identifies as a plumber be one now?
If you look at who's allowed under the rules it's not just those who fit the strict definition of "Plumber".
So long as they aren't asking for help doing plumbing when they ain't a plumber, I am totally fine with designers/engineers being here if they are deciding what plumbing needs to be put in. Technically us plumbers should know all the numbers but usually don't. When we need help with numbers they would be nice to have around.
· Registered
I would like it if we had some more septic system related talk here. A septic engineer would be nice.
· Registered
It's been a few years but I've done a handful of them (designed). Happy to help if I can.
What do you do if a filter keeps clogging? It's normal bits, just more of them quicker. No excessive water flow rates. No excessive grease. All use seems normal/acceptable.
· Registered
Plumbing Designer
Discussion Starter · #16 ·
I don't ever recall this being a problem before. Perhaps the solids aren't spending enough time in the tank before getting pushed out to the leach field? It sounds to me like maybe the tank is a bit undersized and you're not getting the retention times you need to allow things to break down adequately. Do you know off hand what the retention time is? I believe 1-2 days is the norm but the old fellow I worked with always designed for 2-3 days just because of issues like this. The flow rate might not be excessive, but if the tank is turning over too quickly that might be the problem.
Plumbing
Tell us what a plumbing designer is if it isn't a plumbing engineer? Also what is your daily activity consist of?
Well after hitting the snooze button 87 times, i hit the john, then toss a dunkin pod in the ol kureig, i pound that down while reading the local news, then a quick glance at my email, then im out the door. I scream, cry, and punch the windows on my way to work all while resisting the urge to snatch the wheel to a hard right into a row of pine trees beside the ditch and taking the long nap.
· Registered
Plumbing Designer
Discussion Starter · #20 ·
For all intents we're engineers, without the degree (hence the term designer). We do the same thing engineers do, just without the fat paycheck and all that prestige... 🤣
Some call themselves design engineers or some other slippery play on words, but I (and my counterparts) don't have an engineering degree - and I have no desire to pretend I'm something I'm not. Like most designers, I picked up the trade on the job. I cut my teeth doing hospital work, but over the years I've designed plumbing systems for all sorts of buildings (just no residential). I've worked on the Vatican in Rome, designed the medical gas systems for a heart transplant hospital in Palermo Italy, and I've held a top-secret security clearance to work on our embassies all over the world. We design everything from basic waste & vent and domestic water systems to storm drainage systems, condensate drainage systems, siphonic roof drains, medical gas, natural gas, propane, fuel oil, acid waste systems, DI and RO water systems... everything pretty much except process piping. A lot depends on the firm you work for and the kind of work they specialize in. All of our work is ultimately stamped by the engineer of record since we don't stamp drawings. I'm currently a CPD (Certified in Plumbing Design) and I was an NITC certified ASSE 6020 medical gas inspector through the 2018 edition of 99c.
If you've done commercial work, you owe that extra gray hair to a plumbing designer... 👍
1 - 20 of 25 Posts
