There is air chambers on the WMOB, you can see the caps just above the box if you look, I blew it and cut the tees a 1/4" too high.I like how you came up behind the washer box then teed and 90ed out for the actual hook up. Nice work.
I saw those air chambers.There is air chambers on the WMOB, you can see the caps just above the box if you look, I blew it and cut the tees a 1/4" too high.
Where do you see a santee on it's back? The only ones I see look like vents.Isn't it illegal to lay a san T on it's back in a drain application ? It wouldn't fly out here in the bayarea anyway. Nice work though, seldom do you see a plumber who takes pride in there work!
Not if it's used as a vent take off only, no drain can connect to to upper end. Allowed here.Isn't it illegal to lay a san T on it's back in a drain application ? It wouldn't fly out here in the bayarea anyway. Nice work though, seldom do you see a plumber who takes pride in there work!
Those are air chambers, they are required by code here.Where do you see a santee on it's back? The only ones I see look like vents.
Nice job, I've never seen a new copper DWV rough before. What's with the water lines continuing upward past the sink rough?
It is on a 22½ degree angle above the waste, that is legal here.flat ventin' the heck out of that 2" FD. . That illegal as heck here.
You can even tell its rolled on an angle.... Legal here as well.flat ventin' the heck out of that 2" FD. . That illegal as heck here.
Not allowed in Phoenix area but sure would come in handy some times. Nice looking job!Not if it's used as a vent take off only, no drain can connect to to upper end. Allowed here.
