Yep! I don't like the remodel plates for other brands.Is that a Wolverine Brass valve?
I tried to figure out how to turn them but couldn't. How do you do it?Fixed it for you.
Totally agree. There as cheap as they come.Plumb26 said:Yep! I don't like the remodel plates for other brands.
Maybe I'll play with this tablet enough to figure it out.I copied your photos to my computer, then rotated them, then re-loaded them here....![]()
Wolverine Brass. They have chrome, brushed nickel, and oil rubbed bronze. They only fit wolverine brass valves though.i like how the remodel plate has some shape to it and not just a flat piece of metal. looks classy.where do you purchase them from?
IM absolutely positive. Why not change? Customers can't shop you on a brand they can't get. I've been using WB for a long time and have had only a handful of issues that are ALWAYS resolved by my rep. Delta, while there are more style options, are so widely available, it's always a haggling contest when it comes to pricing. Not to mention the valve body is not made of much substance and they do not have interegal stops.I really like the look of that remodel plate. Are you sure those holes won't line up with a Delta?
Are they brass?
I've been using the Delta remodel plates when I change from 2 or 3 handle to single. They suck....plastic.
I'm not ready to go from Delta to WB on my shower valves, but I really do like the look of that plate.
I don't think he enlarged the hole. If you look close you can see chalk around the hole. I think his only choice was with a remodel plate.Redwood said:I get the big hole and the remodel plate...
I rarely use them....
What was on the other wall behind that valve?
I usually find a closet.... :whistling2:
