1 - 14 of 14 Posts
I need to install one of these tomorrow. I won’t be able to find the studs to drill into. Any recommendations on anchors for tile and who knows what the backing is?
Font Rectangle Auto part Parallel Wood
Pornstar, Service Plumber
I second toggles but get at least the 5/16" size and swap the bolts for stainless ones.
Nice Head, what’s in the bag?
I do enough grab bars,
it’s always best to hit a stud on both ends of the grab bar, “drive grab bars” have a swiveling flange to help with that.
But you can’t always hit the stud, depending on the length of the bar or the angle it’s to be installed at.
I use a Bosch stud finder with deep scan which hits 90% of the time in homes with wood/steel studs.
On the holes that don’t/can’t hit a stud I use these cobra wall plugs(see below, heavy duty, once they bite in- they really hold, I’ve been using them for years never heard a complaint)
Note: I avoid apartment buildings and condos for grab bars- it’s almost impossible to find/locate the thin metal channel used to secure the wall board.
Font Knee Parallel Human leg Screenshot
In my Apt. when I asked for grab bars for my tub/shower they installed them Vertical outside both ends just so they knew
that were going into studs, even though they still only managed to get two screws into the studs
We usually install one vertically on the outter edge to help getting in and out of the tub/ shower and one horizontally or on an angle (45 deg-ish) inside the surround to aid in bathing from a sitting(chair/bench) or standing depending on the clients needs.
Thanks for the recommendations. When I called her this morning to confirm our appointment this morning she told me her brother installed one for her over the weekend because she needed it right away. Saved me a trip to Compton.
This compton??
One of the last things my dad and I did together was install grab bars in his shower. Cancer was growing so fast in him I went with toggle bolts. I did not worry about long term much but I did swap the bolt out for stainless. My dad couldn't do much but he sat on the toilet and handed me things as I needed them. Those bars are level and rock solid.
1 - 14 of 14 Posts
