what is the elbow to the left going to???
If you actually read what I posted before you would know.
The only time we can put a tee lying down is for vent purposes. Has to be rotated no less than 45 degrees.That tee on its ack is just fine,nothin wrong with it at all
Kentucky allows tees on their backs,hell if you do many undergrounds you would know that you can't always use a wye and 45 turned straight up on its back,it's to tall,your ditch would have to so much deeper just to get one fitting below the slab,you have to install tees on their backs or sides at 45 degrees,if you use wyes and 45s that sticks up what 20inches or more???way to tall for underground workwhat code do you go by?
I'm not saying laying on its side,that a Nono,the tee has to be turned straight up(on its back) or on its side on a 45The only time we can put a tee lying down is for vent purposes. Has to be rotated no less than 45 degrees.
Wow that's some serious old $hit! I'm surprised they paid, it would be a full day ordeal trying to get some pipe to fit in the chrome. Then I'd get the reply they'll call the duct tape guy.The leak was on the 1-1/2" lead going into the bottom of the drum trap. I could have soldered it shut but decided to just replace itI cut the drum off and left the lid in place so they didn't have a hole in the floor. Unfortunately the tailpiece that was soldered to the lead was too short to reuse so I used some 1-1/4" L instead. I wasn't going to call back to the shop for that.
I had to shim the tub because the floor was so wonky the tub wouldn't completely drain out.
They were eating dinner when the child noticed the ceiling had developed a basketball sized balloon in the paint. The homeowner got a trashcan to pop it. Called one of our guys out on overtime to make sure it wasn't active. Manager came and punched a couple more holes to find the lead pipe leaking. Because the ceiling was sloped it looked like the toilet line was leaking which of course is a lead bend into cast iron. They had a carpenter open the whole ceiling as they are making an insurance claim. Unfortunately their insurance doesn't cover the plumbing repair, only what was water damaged, and of course there's a deductible.Wow that's some serious old $hit! I'm surprised they paid, it would be a full day ordeal trying to get some pipe to fit in the chrome. Then I'd get the reply they'll call the duct tape guy.
Same here, insurance pays for damages not the plumber's bill.They were eating dinner when the child noticed the ceiling had developed a basketball sized balloon in the paint. The homeowner got a trashcan to pop it. Called one of our guys out on overtime to make sure it wasn't active. Manager came and punched a couple more holes to find the lead pipe leaking. Because the ceiling was sloped it looked like the toilet line was leaking which of course is a lead bend into cast iron. They had a carpenter open the whole ceiling as they are making an insurance claim. Unfortunately their insurance doesn't cover the plumbing repair, only what was water damaged, and of course there's a deductible.
Depends on your tank or sewer tap lololololo that's what decides how deep or shallow you can goIf the trench needs to be deeper to accommodate the taller fitting, so be it. You are only talking a few inches.
In the pic with the hydrant,what is that black fitting or pipe that you used between the new brass and old galvanized pipe???doesn't look familier to meView attachment 126466 View attachment 126471
Getting rid of the cast iron tree that the abs plumber left in 30 years ago and the excavation company also left in 5ish years ago. It kept clogging on them simply because of how rough it was. Also had no pitch. My picture doesn't show it well but I was able to add about a 1/2" of pitch. The two 3" abs lines are both 30'+ long.
View attachment 126467 View attachment 126468 View attachment 126469 View attachment 126470
My manager failed to mention the customer told him the hole started to collapse with some rain we had. I did that one this morning. Fun fun, wake up and dig out 20 gallons of mud in the freezing cold. As you can see the neighbor with the backhoe couldn't be bothered to put the spoils anywhere except right next to the hole so they could easily fall in again.
It was easy to cut with the angle grinder. Only 2" cast. I cut 90% of the way through and used my beater in the seam to pry it apart and crack the remaining bit."I had to shim the tub because the floor was so wonky the tub wouldn't completely drain out."
That cast line you tied into must be over 100. Must have been fun cutting. Was it thin on the bottom?
There's no galvanized fittings. That's a piece of 1" black polyethylene water piping attached to a 1" brass insert female tee. The run has a 3/4" male pex adapter with fostapex.In the pic with the hydrant,what is that black fitting or pipe that you used between the new brass and old galvanized pipe???doesn't look familier to me
Ok,gotcha,thanks just looked weird in the pic,thought it might be something new lololoThere's no galvanized fittings. That's a piece of 1" black polyethylene water piping attached to a 1" brass insert female tee. The run has a 3/4" male pex adapter with fostapex.
I said to the guy, that fostapex run looks new, the plumber didn't offer to change out the hydrant when it was dug up? He said he asked the plumber and was told if the hydrant worked don't bother. That was less than 2 months ago lolz. Some guys are too lazy, should have changed this hydrant then.
That looks rather sexual,you are the hero lololololForgot to upload this the other day. Basement company put sump pumps and vinyl down 10 years ago. Some jackwagon cut a 4" pvc saddle fitting in half longways so they could glue it onto the 6" cast iron. There's no pic of the saddle fitting because the maintenance guy absconded with it before I got back in the tunnel. They had drilled a 2-1/4" hole so a 1-1/2" toilet spud was perfect. It's rock solid. I screwed a cleanout onto the spud.
I thought about running 20' of 1-1/2" down the tunnel to a cut off 4" line but when I realized how well the spud fit I couldn't justify it. This was the old school main waste line. They ran a new line over head to a new septic system and now only use this one for the sump pumps, a couple floor drains, and a mop sink or two.
View attachment 126486 View attachment 126487 View attachment 126488
