201 - 220 of 258 Posts
Ok good so glad you weren’t but hurt as I see you say all the time lololololol
Did you really think I was going to make a federal case out of it? I wasn't being accused of inciting an insurrection! lolz ;)
I use propress when it makes sense. I love my Trimo. Added new shut off and hosebibb.
127959
127960
The trellis had been cut to fit the old bent copper that was there so I bent a new piece to replace the burst one.
127970
Do they even make 3/8" OD slip couplings? Now I need some ;)
Had to remove spout for pink granite top repair. The valve bodies wouldn't budge, deck nuts corroded in place with very little to grab.
I put the new ceramic stems in so it's better than any of the modern crap available for less than 600$.
127971
127972
127973
View attachment 127971 View attachment 127972 View attachment 127973
That Kolher faucet look brand spanking new! I need their huosekeepers name! I love the ceramic cartridge replacement for the valvet system. Thanks Kohler!
Stub out and winter drain for hose spigot.
This is my own house.
Right next to a stair case so I made it pretty flush with the wall and ran the drain down so I could set a cup on the step. I cut a groove for the pipe to sit in. The pipe couldn't go any higher without getting into the plaster on the outside of the house which I did not want to risk cracking. There was already a hole here through the hardwood sill plate and it was on an angle.
I added a slate(with pitch) and cemented next to the house to prevent water ingress.
128023
128024
128025
I had one really large cast iron shelf bracket.
Don't let richard bull see this, he'll claim it looks backpitched compared to the wall lolz.
128028
128029
128030
More of a story than a picture. Fill valve was running, stop didn't work, and anti-sweat valve was only letting hot through. Woman said the toilet was so hot she couldn't sit on it. It's a tall toilet too!
I ran out of torch gas and had to search through their two bay garage full of carp for a can. Only found a full 20lb tank on their grill so I used my hose and adapter and lugged the thing upstairs. Problem was it was only a 3' hose because it was just meant to put the 1lb tank on your hip so I had the 20lb tank on the toilet lid the whole time.
128031
When you really need a cleanout.
128034
128035
Brine tank with ~200# of salt still inside.
128037
128038
Plastic flange had the outer portion ripped off so I added a new bolt flange and filled in the gaps with hydraulic cement. It was slab of course, in a pool house bathroom. Used a horned gasket.
128041
