1 - 20 of 25 Posts
All ,,, I DO NOT buy into infomercials ,,, However , this Shamwow towel thing is truly amazing ! I am starting to use them for everything !
Let me say this DO NOT get the cheap knock offs ,,, get the real ones from germany ,,, the ones with the wacky dude on t.v.
I drain a toilet and tank quickly and with a lot less mess then a sponge . Have them under a sink and it soaks up all that excess water when changing faucets , ,,, just all kind of things .
Machine wash and go again !!
They work on everything and I just wanted ,my plumbing siblings to know!
Cal
I was shocked at how well they work !!
Cal
Always Something
"Hi it's Vince from Sham Wow"
The only reason I didn't buy any was because I saw it on TV too. I just refuse to buy crap off tv....but if you guys say it works well. How well does it wash out with flux and grease and other stuff on it?
LeMarr Plumbing, Inc.
Awesome, a real testimonial! I will need to get some.
I use a 2 gallon shop vac to get the water out of the stools. I love it.
In Christ,
Song Dog
In Christ,
Song Dog
I to use a wet vac, mine is 5 gal, I use the wet vac in many ways, like removing the water out of a meter box to fix a leak, when cutting a line to remove the water from the line needed to get fixed in a quick way, removing the water from a 20 gal water heater which inlet is on the bottom side, no drain valve, and drain valve never was was installed when new. :no:
I use a shop vac for toilets too. If I am just working on the tank, I stick a coffee can below the fill valve and let the remainder drain when I pull the valve.
I think I'll get some of these though. I can see many uses for it like under a sink. I always make a mess :)
I'll second the question - How well does flux and all the other nasty stuff wash out of them? What can you *not* use it on?
Discussion Starter · #8 ·
What I have done is this ,,, use one to a point of death / discard ,,, then it becomes my solder rag . At that point ,when it is too fluxed up it gets discarded .
You can wash these things in the clothes washer ( DO NOT ,NOT PUT IN DRYER )
But I don't want flux / grease etc in my washer .
IMHO
Cal
Discussion Starter · #9 ·
I use a piece of rubber pan material THEN a Shamwow under sinks , vanities ,etc .
Really protects the cabinet . Easy clean up :)
Guess they could change there ad on TV to say 9 out of every 10 plumbers recommend them. :laughing:
I use the wet vac as well, i have the milwalkuee one that looks like a toolbox, but what the hell, it aint a tool box, its really a wet vac!!!
Yea, I also use a wet vac but mine is 55 gallon :thumbup:
You have a picture of this, never seen a 55 gal wet-vac. :no:
1 - 20 of 25 Posts
