....Of course some old pcs. of crap kitchen faucet is getting replaced. ...That I replace. But old antique and vintage plumbing fixtures and faucets are well worth the effort to repair.
yes and no.....depends on what the cost is for finding and running for parts if you dont stock them..if you spend more labor doing that then just replacing does the customer want to go that route, it depends on what the customer wants and if it makes sense financially......
Today I had a slop sink with a CB faucet, pretty common. I suggested it wasn't worth touching but the handles were hard to turn and the customer has bad arthritis. They asked me to try to fix it instead of leaving it to replace later. When I took the handles off they each lost a small chip out of the female stem hole, luckily neither chip was in the splined are. Both packing nuts had a lot of build up but they cleaned up well and didn't leak. It turned out to be old enough to be pretty quality, only part that wasn't solid brass were the zinc handles which of course I forgot to put on my WB order I sent in when I got back to the shop.
I want to stock some of those handles as CB faucets, especially on slop sinks, are really common around here. If a slop sink here doesn't have a real CB faucet it's a compatible knock off. WB has a CB kit but it doesn't seem worth it, I just ordered some seats and 4 stems for less than 20$. They wanted like 60$+ for a kit that has really cheap stuff like washers and screws.
Unfortunately I used my last ce-1 seats this month, in brass that is. I put in two 4$ ss/monel seats instead of two 0.40$ seats. I was so pissed at my self. Both seats were corroded so I guess her water may be acidic. At least it was a good faucet.
We repair it if its more hassle to replace like sometimes you have to repair because it's kind of built into bathroom and new just won't look right.. We dont really get into too much ancient stuff where we can't find parts but have had make things work.. like I've seen some things where there is leather involved before the days of rubber so it's out there......
Customers really appreciate you fixing a shower valve in a costly to open wall when the last couple companies said they don't fix old stuff like that. One lady was so peeved with the last couple guys because her father had serviced this 3 handle kohler multiple times when she was growing up and he wasn't even that handy.
