Would you leave a toilet rocking like that for your customer?
Have seen a back outlet set with oakum, did not leak for 50 years.PUTTY!!!!!!!:laughing:
Oh, sorry. wrong thread. :laughing:
OK, I watched the video, (2) questions:
1) What's with the dark, dark, really dark Grout?....:blink:
2) Wood shims?
The grout looks absolutely horrible. Why not use silicone?
Also if I have to shim i use plastic.
That grout is going to wick moisture when ever the floor is washed. Unless you sealed it after.
Should look fine painted. why not white? Or do you just keep gray in the truck?
I personally would have filled that with silicone. I keep old credit cards in the truck for shaping.
White grout? or white hydraulic cement?
I used hydraulic cement because I can use hot or cold water, hot if I want that to set up in 90 seconds. Gotta be super fast though.
The idea of a marble slab was knocked off the idea list because it puts a hard raised edge on the two front corners, and sometimes those slabs don't reach the full footprint of the toilet.
I use silicone 95% of the time if the margins are narrow for sanitary and finished look reasons, occaisional shim if the floor or toilet is uneven to stop rocking.
This customer was requesting grout from the go, so I told him to let me use hydraulic cement so he could use the toilet right away.
If he uses the right color white, that will look invisible to the base, and if they ever replace the linoleum they can cut it right at the edge of the grout line.
Using old credit cards would give me waaaaaaaaay too many bad memories just seeing them.
That is so wrong on so many levels.
Exactly how long do you expect those pine shims to last?
The shims were temporary to get the grout underneath.
I don't care if the shims disintegrate in a day, that's not what is holding that toilet level and solid.
Alright. I misunderstood.The shims were temporary to get the grout underneath. A toilet that is properly installed will never leak underneath, ever.
You're wrong.The shims were temporary to get the grout underneath. A toilet that is properly installed will never leak underneath, ever.
