1 - 20 of 22 Posts
Phat Cat said:
Kinda like sharkbites? :rolleyes:
Yup
Those seals tend to compress and then over time loose their compressibility leading to a leak
sent from the jobsite porta-potty
Reactions: Phat Cat
When I first joined this forum I seen the add for these and emailed them asking for a sample. They sent me 2 out right away! They are similar to a zurn gasket but the foam is softer! I haven't used them yet but I will use one at my house or a freebie job next time I do one to test them. I won't experiment at a customers house.
IMHO the price is to high still $5 apiece is more than plumbers wanna pay to reset a toilet. ALso wax rings work fine why switch?
Mississippiplum said:
Yup
I dont think it could be any worse than a seal on a carrier toilet. One of those zurn gaskets. Actually, it would work better as the seal wouldn't move as much like a carrier toilet does.
Yup
How many of these Sani Seal gaskets have you installed? Of that undoubtedly large number, how many have failed and lead to a leak?
Paul
Paul
I've seen ones leak that hacks have installed, have I installed any? No, why should I, there's nothing wrong with using a wax ring. Wax is tried and true.
Former Moderator
Discussion Starter · #10 ·
I can see a lot of H.O. using them. If they do work at all, I'm sure Lowes or Home Depot will jump on it.
I clicked the ad for Nathan. Haven't seen any around here.
BKPlumbing said:
Radiant heated floors.
I'm guessing the heat melts the wax in wax rings?
Texas turd-herder
The radiant tubing is supposed to be no closer than 12" to water closets, but how well that is enforced I don't know. I can say that I've reset more than a few closets over the years where HO's put space heaters pointed at the water closets and melted the wax seals, though ;)
I've never run into radiant heating melting wax seals, but I've been out of residential for about ten years...the radiant heating was just catching on down here about that time as I recall.
Reactions: GREENPLUM
I use foam on a junk load of wall hung toilets and urinals that get an industrial workout. I have never had a problem. I have seen lots of wax rings that have been plunged by.
I don't know how good the foam is but if I get a chance I might put some in at that same mill on their floor flanged toilets.
1 - 20 of 22 Posts
