This was a pretty sad story. An older couple had an RO System installed by one of the big box home improvement stores and after a few months water kept coming from the hole in the side of the RO faucet. They contacted the store which sent out a company that installed a new system, within a few months the new system started doing the same thing. The owners called the store again and had a different kind of system installed. To their dismay, this system did the exact same thing as the other 2.
Within a half hour I discovered the horrible drain connection just below the disposer 90 through a saddle to be the culprit. The drain line enters the waste system in a horizontal manner which allows food particles to collect and build up in the drain line, ultimately plugging the line up after a short period of time. I cleared the line and purged the system. No leaks were found afterwards.
This is a perfect example why the contractors board should eliminate c30 licenses, a license to install water treatment equipment which in my opinion is in violation of Nevada law which requires a plumbing contractors license to touch any part of the water, drain, waste or vent system of a building. The manual clearly states that the drain line of an RO system should enter the waste system in a vertical manner, preferably through the 90 degree connector they provide.
Joe Blo gets a C30 license and takes advantage of home owners by ignoring plumbing code and the safety and health of the public by slopping these units in over and over. Wheres the justice?
