Removing this tub drain
8777 Views 19 Replies 15 Participants Last post by  vinpadalino
The cross in the drain for the tub key broke off, Im pretty sure its the drain thats leaking, I don't have a dremmel so is there another easier way to get it out? Im thinking a hack saw and cutting it in half.
1 - 20 of 20 Posts
There is inside wrench for bathtub drains ... they should have them at your suppliers
I cut a notch in it with the sawzall and finish the cut with a small hacksaw being very careful not to nick the porcelain then collapse the threads with a flat head... unless you're a spaz then stay away from the sawzall.
Reactions: 3
I usually cut a couple inch notch out of the shoe trim and try to get it to either turn out or squeeze the trim to pull it out, as stated before, if you're a spaz don't do that..
Reactions: 1
This be the way to go... :thumbup:
See less See more
3
Auto part
Auto part Drain Rim Wheel Circle
Washer Fastener Auto part Hardware accessory
Diamond blade angle grinder, 4" blade, be veeeeery careful get a groove so a screwdriver can be hit with a hammer. <<< I love incorrect tool usage, but it works.​
It'll come out every time. If there's a way to do it easy, I've found it already. :laughing:​
See less See more
On a PVC shoe it"ll most certainly will work every time but I don't see how that's going to work on something that's been together for over a decade. BTW a hammer works wonders on anything PVC that needs removal :yes:
I get them all out, same way. On the old brass ones, just hit a lot harder... sometimes you have to send it clockwise then counterclockwise to break the threads open.
Reactions: 2
That's exactly what I was tought and unless its a new efd up install I don't even try any thing else (except I'm like a surgeon with my sawzall so that's the scalpel I use)
Sent from my EVO 4G using Plumbing Zone
Great idea's! I appreciate the help.:thumbup:
Ridgid internal pipe wrench, works wonders
Reactions: 1
You can also heat the spud up with a torch. Then shock it with some cold water. We've done it hundreds of times.
Hammer and chisel is also a great way.
If your replacing the the whole w/o and its a cast tub, I cut the shoe off from the back of the tub with a sawzall.
I use the Ridgid internal wrench first and if that doesn't work it gets cut with a saw and then broke loose with a screwdriver.
Reactions: 1
I have that tool, it SUCKS! I have a different one If I remember I will take a picture of it I will. It works a lot better!
I have to one one this week. If the drain doesn't come off with a wrench and screw driver I break out the sawzall and putty. It works every time. I was going over how much should charge for that? Any good ideas?
At least $ 5.00 :laughing:
I collapse them and peel them
I talked to some buddy's in the trade. I'm going with $285.
1 - 20 of 20 Posts
