http://us.grundfos.com/products/find-product/comfort-pumps-up-10.html
What's better? What's worse? Why? Any other thoughts on these?
I install a faucet with a hot water lever on the left side when the homeowner wants hot water.Will said:I'll install them on a switch that can be flipped on when the home owner wants hot water.
When you gonna fix that broken record?rjbphd said:If installed properly, you don't need any stinky pump on re circ line!
When they learn how to pipe the re circ line correctly..When you gonna fix that broken record?
If Moen ever decides to make a pump there will be no living with him at all. :laughing:When you gonna fix that broken record?
You got anything intelligent to add to that?MTDUNN said:I install a faucet with a hot water lever on the left side when the homeowner wants hot water.
I whole heatedly apologize for my witty response. I have absolutely nothing intelligent to ad sir.Will said:You got anything intelligent to add to that?
where do you put the switch? Any difference between the grundfos or the watts? They look the exact same to me, just a big difference in priceI actually like those. I install them to be used at certain times(6am-8am, 6pm-10pm etc) and not to run 24/7. Or I'll install them on a switch that can be flipped on when the home owner wants hot water.
Have you tried the motion sensor ones? They work pretty good also.I actually like those. I install them to be used at certain times(6am-8am, 6pm-10pm etc) and not to run 24/7. Or I'll install them on a switch that can be flipped on when the home owner wants hot water.
any links or names?Have you tried the motion sensor ones? They work pretty good also.
I'm pretty sure it was Laing.any links or names?
I use Grunfos with the grey valve installed in a vanity and have had no problems -- except and this is not a Grunfos problem. If the toilet has any kind of a small leak the tank water in most cases will get hot. Usually happens with any fill valve that drops a inch or two before it fills. Like a F/Masterhttp://us.grundfos.com/products/find-product/comfort-pumps-up-10.html
Anywhere the home owner wants it. Master or kitchengear junkie said:where do you put the switch? Any difference between the grundfos or the watts? They look the exact same to me, just a big difference in price
I haven't used those, remember seeing them in continueing ed. Have to check them out, I like Grounfos though, I think they have the best productPLUMB TIME said:Have you tried the motion sensor ones? They work pretty good also.
Yea... Leviton...any links or names?
