........I've done many roughs in tight places with press and I couldnt even tell you the last time I had a leak, knock on wood. I always plan ahead because I'm service minded.
I didn't even get a permanent propress on my van until 6 months ago, didn't make sense. They'd send me to do all the repairs in tight quarters that some install guy made a parts lists for but would make some comment about it not being possible without them burning the place down or how I am good at it so they should send me. Most of the time the office wouldn't bother having me grab the parts because I have everything on the van.
The one that really sticks out in my mind is this cabin. 10x10 access panel in the ceiling of a first floor bathroom, it's the lines for the 2nd floor bathroom and some drains. Dingle rookie goes and sees tight spot, several bad joints/bursts. Orders all propress stuff. I show up to the job and know this ain't going to happen. Aside from the fact that you couldn't even fit the propress in to do one of the joints, even with prefabricating some stuff first, there was no way in heck you were going to fix it a second time if the customer broke it again without opening some of the plaster ceiling. So I soldered it.
Ever try to winterize a place that has propress fittings? They hold water because they deform the pipe. Even if you get the pipe clear, humidity in the air can deposit water in the pipe when the temperature changes. Propress fittings have a lot more mass than the rest of the system so they heat/cool at different rates. And, even blowing a system out with a compressor nothing is 100% dry, only 99%, and that moisture colllects together if it can. We had a couple places back before we learned this where we used propress couplings and then the next year it would burst in the same spot, pushing the coupling off. At least with solder you can just solder it back together when the fittings push off.
Customer would want to save money so they would drain it themselves. They'd have us come in the spring to fix all the breaks. We tried some propress because it was the new thing. The next year when they had us winterize it to avoid breaks, we got breaks in the same darn spots pushing the couplings off. WTF? Must not have winterized properly, darn. New propress couplings a second time. Happened again! That's when we realized something funny was going on because we knew it was winterized properly that time.
And with solder you never have the diminishing pipe problem. Everytime you cut a pex, propress, or compression joint off the pipe gets shorter. I can unsweat solder fittings and reuse the connection. And yes, I know sometimes you can remove the compression ferrule and reuse the joint.
