OK, I used to pride myself in private well repairs. I especially loved jet pumps. Yes, they are a bit tricky to get just right, but you cant beat them in my opinion.
Last night I had a call to replace a kitchen sink and faucet. Its at a friend of a friends house so the HO had the sink and faucet. I installed them and when I turned the water on the pressure was piss poor. My first thought was the aerator. I removed it and the water saver and still low pressure. I went out and tried the hose. So low wide open only sprayed water about 2 feet away from the end of the hose with no attachment on it. So I started checking:
220 volt submersible pump
110 on each leg at the switch and out to the pump
4.5 amps draw on each leg (So I know there is no broken wire at the pump)
Replaced the pressure gauge and it reads 50 pounds.
Pump comes on at 30 pounds
Goes off at 50
Checked the line under the pressure switch, is all clear
Replaced switch thinking resistance in contacts.
has a 1" 180 PSI poly pipe feeding the tank tee (Black roll pipe)
I built up pressure in the ballast tank, then removed the switch, the gauge, the plug ahead of the check valve and all have strong pressure. So I know the check valve and the ballast tank is working good. I then built up pressure and removed the rear plug from the check valve and nothing, so that confirms the valve is holding good.
Removed the whole house filter and bypassed it, still poor pressure in house.
Checked the lines, she has 3/4 copper main with each fixture tied directly into the 3/4 main, no reduction in pipe size at all.
Held the switch closed and maxed out the pump at 70 PSI. Go into the house, same thing, no pressure difference.
Checked the air pressure in the ballast, with zero pressure on the water side I have 28 lbs on top of the tank which is right, the tanks air pressure with no water pressure is set at 2 lbs lower than the pumps cut in pressure
I think some how there is a restriction somewhere, but thats ususally in galvanized pipes, or a broke valve someone turned off and when you turn it back on it dont open fully.
The outside faucet only gets 28 lbs of pressure even though everything reads normal.
Any thoughts??
Goes off at 50
Any thoughts??
