1 - 5 of 5 Posts
A quick question for you - Do Pressure reducing valves (e.g. Watts 25-75 models, etc.) allow backflow due to thermal expansion from the HWT, back into the City supply?
J. McCabe Plumbing Inc.
Not likely, but possible if the pressure downstream was to build in excess of the incoming pressure.
N55's has a built-in thermal expansion bypass that's supposed to open at 135psi only if the main line pressure is lesser.
Most, if not all PRV's are backflow devices by default. If you install a PRV, it's automatic for an expansion tank or device in connection with dealing with thermal expansion. T&PRV does not count.
The 25AUB34 is one of the most reliable PRV's out there, but I use the N55's because they are shorter, and I get them with 3/4" sweat unions so installation and replacement is a cinch.
we use wilkins prv's exclusively and i know the #70 has a bypass. i was told it opens at 150psi but i don't see how that would help if the t&p pops at the same pressure. they could be set to bypass at 135psi too, would make more sence. either way, they do have a bypass for thermal expansion.
paul
1 - 5 of 5 Posts
