We do, it’s between 6am and 8am. Then it’s spring til lunch.You don't have winter either.
Its 59 right now, 75 by lunch.
That particular Jomar I posted is made in China.In 2003, RED-WHITE VALVE CORP. was acquired by Valvoindustria Ing. Rizzio (VIR) of Italy. Renowned for their fifty years of manufacturing the best bronze and brass valves in the world, VIR added to RWV the ability to supply our customers the highest quality products with the industries best brand name.
Jomar is affiliated with Fratelli Pettinaroli Group.
My R-W rep says their ball valves are made in Italy.
My Jomar rep says the 100 series ball valves are made in Italy as well.
This is true and highly valued. I’ll be in shorts and flip flops Christmas Day. Probably hit tennesssee At thanksgiving for my annual dose of some type of winter.You don't have winter either.
Thursday I installed a softener in a crawlspace. Manager ordered me all press fittings. I was getting the old one out and was thinking screw that I'll solder the new one in. Then I smelt a touch of propane. Had me helper get my squirt bottle and found the union on the furnace right behind my back wasn't even finger tight!!! decided this one could just be pressed in.Maybe I am just old school, but I never cared for press fittings. I'm not meant for that club and it's not meant for me.
It's funny you mention how things are bid. Because I am quite proficient with soldering I can often complete something like a softener install fast enough with sweat fittings that it costs the same. Press fittings cost a lot and our quotes are made not knowing exactly whom will be sent to do the install. I don't fool around so I will generally be 30-60mins faster than most other guys depending on the job.I don’t like PEX or propress either. However, as you stated, a lot of the time, we have to use them in construction; projects are just bid that way. Luckily, there are a fair number of jurisdictions that will not allow plastic pipe of any kind, nor will they allow pressed fittings on copper pipe.
I also still find a lot of value and time saved in being a little old school like using a tee extractor. The joints have to be silver soldered but it is far cheaper than pressed or even regular fittings on large diameter to small diameter pipe.
For me, in my world, it’s plumbers vs design engineers vs code.There’s no way that I’d build a house and use copper press fittings. It’s just an inferior method to soldering of joining copper tube.
It uses orings to seal. Enough said.
Some are made in Italy, some in China. Not sure how they decide where to have what produced.In 2003, RED-WHITE VALVE CORP. was acquired by Valvoindustria Ing. Rizzio (VIR) of Italy. Renowned for their fifty years of manufacturing the best bronze and brass valves in the world, VIR added to RWV the ability to supply our customers the highest quality products with the industries best brand name.
Copper for Nat/Gas or LP?I pick my materials based off the install conditions.
In that case here it goes.
Soldered copper for water( city water )
Rehau pex a with Boshart stainless fittings. (Well water)
Brazed copper for gas
Pvc for DWV
Right now In my area, that’s what I’d use in MY new home, nothing else considered except for reasonable cost.
BothCopper for Nat/Gas or LP?
Makes sense.Both
I’m not opposed to steel pipe inside the structure. But I’d still use copper in my area because it has a proven track record for over 50 yrs with no significant problems.
With the salt air and one of the top rainfall totals in the continental United States, steel piping outside or in a crawlspace isn’t desirable,
